Robot movements smoothness
  • Ceta11
  • December 5, 2017 at 6:40 AM
  • TylerRobertson
    70
    • December 18, 2017 at 10:35 PM
    • #21
    Could you post a sample of your milling file, with the header and approx 20 lines of code? Depending on motion parameter/zone settings, point spacing, speed, direction etc. this can be solved without diving too far into anything else.
    Taylor Guitars - Robotics Engineer
    - IRC5 IRB4400
    - IRC5 IRB2400
    - S4C+ IRB4600
    - S4 IRB2400
    - Epson G3-351 RC180
  • Ceta11
    Guest
    • December 19, 2017 at 10:48 AM
    • #22
    Note: and again jogging the robot produces the same X-Y pulsing than during program running.
    Here is a small piece of a code for rough cut on foam I just did.
    Thanks for your comments and ideas.
    Files
    SampleCodeKUKA.doc 29.18 kB – 25 Downloads
  • TylerRobertson
    70
    • January 3, 2018 at 6:52 PM
    • #23
    If jogging produces the same problem then the programmed path isn't as suspect (although the points appear pretty close together for the speed). I don't see anything in this that jumps out at me - I've seen in some cases where tool-changing was happening, a tool was activated and either the LOAD_DATA wasn't changed, or there wasn't anything in the LOAD_DATA for that tool.
    Make sure this:
    ; LOAD_TOOL(1)
    BAS(#TOOL,1)
    is activating the right LOAD_DATA. You can also force it out ... I don't have the syntax in front of me so you'll have to look it up but it was something like
    $LOAD_DATA = LOAD_DATA[1]
    or if using Tool 2
    $LOAD_DATA = LOAD_DATA[2]
    and each tool will have to have the specified load data in it.
    When jogging after running a program its possible to still have LOAD_DATA[2] activated while jogging with TOOL1 if changed manual.
    - IRC5 IRB4400
    - IRC5 IRB2400
    - S4C+ IRB4600
    - S4 IRB2400
    Edited once, last by Tyler Robertson (January 3, 2018 at 6:59 PM).
