Hi all, we have a S-420F connected to an RH controller, we want to be able to use the positional variables from an already made program to use them in another program but the .VR file need to be rename in order to work... The problems are the following :
If i just try to copy the .VR file with another name all coordinates say "not recorded" even tho all the variables names are there.
I also tried "load all low932m" ans then rename the low932m.vr to low485m.vr and then save the loaded variables back into a new low932m.vr and it still says "not recorded"
The way I was told to do it is :
KCL >load all low932m
rename the low932m.vr to low485m.vr in the files utilities
KCL >save low932m.vr
and then copy the 932 KL files into 485 KL files, modify them, load them into the teach pendant and then adjust the teached positions if needed
I'm trying this over and over again, I think I got it once but because I restarted the Controller I lost it....
Please help, I'm losing my hair rapidly, thank you.
