Anyone familiar with this integrator Cloos or Qirox robot if so what are it's advantages/disadvantages as compared to Fanuc or ABB for welding application?
Cloos Robotics/ Qirox robots
Capin -
October 2, 2017 at 11:43 PM -
Still looking for feedback on Cloos robots...
I am just on project with Cloos robots. Robots are very simple, like toys. Not usable for complicated application. He knows just welding.
Jeśli chodzi o Cloos, robot dość często może stracić odniesienie (orientację pozycji) bez kolizji i skoku napięcia. System może również często ulegać awarii i muszę ponownie uruchomić komputer. Największą zaletą cloos jest czujnik śledzenia spoin SSPD, nie musisz ustawiać go na próbkach, wystarczy wprowadzić wartości od 0 do 20
When it comes to Cloos, the robot can quite often lose its reference (orientation of the position) without collision and voltage surge. The system can also crash frequently and I need to restart the machine. The biggest advantage of cloos is the SSPD weld tracking sensor, you don't have to set it on the samples, you just enter values from 0 to 20
