hello, everyone,
I will lock the screen with only one display by variables or karel,
if anyone knows about controlling the number of display, thanks in advance
Chandler
hello, everyone,
Chandler
In the variable $ UI_CONFIG. $ MODE, you can see the status of iPendant
3 = Single
5 = Dual
6 = Triple
But changing this variable will lead to nothing. It's just a poll.
To be able to change the number of screens from Karel, you need to study the instruction- iPendant customization (Generic Linking Detailed Information)
Example how to use from KAREL would be:
force_link(TP_PANEL, '/SOFTPART/GENLINK?CONFIG=DUAL')
Thank you so much, I will have a try
I'm too excited, because I did success in forcing the display-number of screen with the help of Mr. 'lexx905'
I share what I tested with everyone about the karel program as followings
PROGRAM force_screen
BEGIN
FORCE_LINK(TP_PANEL,'config=single') --single/double/triple means how many screens can be dispalyed
END force_screen
for more info.
FORCE_LINK(TP_PANEL,'Focus=prim') --prim/dual/triple means the current pane will be forced to the first or second/third pane
I hope I shared useful information
-- Set pendant display to three screens:
-- program select, robot io and current position.
FORCE_LINK(TP_PANEL,'CONFIG=TRIPLE') -- Set to 3 screens
-- If currently not triple screen layout, give it time to load.
IF $UI_CONFIG.$MODE[1]<>6 THEN
DELAY 300
ENDIF
FORCE_LINK(TP_PANEL,'PRIM=MENUPAGE,71,1') -- Select program screen
FORCE_LINK(TP2_PANEL,'DUAL=IOPAGE,107,1,OUT,4') -- Robot output screen with no. 4 selected
FORCE_LINK(TP3_PANEL,'TRIPLE=MENUPAGE,33,1') -- Current robot position screen
FORCE_LINK(TP_PANEL,'FOCUS=PRIM') -- Set focus to left screen,
Hi everyone,
Thanks for "Force link" it's very useful.
I need to know the current screen on the differents panes.
I got it in karel with : Test2= $TP_CURSCRN[1].$SP_ID but it only work for the primary pane.
Do you known how get it for the second and the third pane ?
