Hello
I need to send register value from PC (VB program) to robot 200ic.
any VB 6 example will appreciate it
Help VB example with PCDK
dzrobot -
June 17, 2017 at 3:05 AM -
This is not specific to any language, these strings just need to be sent as http requests to the robot.
Use with extreme caution:Set numeric register 20 to the value of 999:
[robot_ip]/karel/ComSet?sValue=999&sIndx=20&sRealFlag=0&sFc=2Set the comment of numeric register 20 to "I'm in your mind":
[robot_ip]/karel/ComSet?sComment=I%27minyourmind&sIndx=20&sFc=1Note that Karel needs to be unlocked in HTTP setup.
Source for this information: The javascript that runs comment tool on the robot.
Thank you very much
one more question: how to unlock karel in the http setup.
Thanks again -
Thank you very muchone more question: how to unlock karel in the http setup.
Thanks againGo to Menu, Setup, and then Host Comm. Cursor down to HTTP and then press Enter. Once there just cursor down to Karel and press Unlock. I usually just unlock all of them at the same time.
