Can anyone please help me to understand One step tip dresser program in Fanuc R-30iB.
Fanuc one step tip desser programing.
Yash Awasthi -
May 29, 2017 at 7:56 AM -
There are two programs when you use the One-step method to measure the tip wear.
The first is WR_SET01 that initialize the values for the tip wear. This should be run only once, when you set new tips on servogun
The second in WR_UPD01 that is used to update the values of the tips after to goes to tip dress or tip change.
Inside of WR_UPD01 you will find a program called WR_UPDAT(1, 2nd argument), where you should set the value of the 2nd argument to 0 if the update is done using worn tips, and set 1 if the update is done using new tips.
