I have an rj3ib and when the switch is turned, nothing happens. Input power is ok. Any other ideas?
Rj3ib power up issue
CPU_Malfunction -
March 15, 2017 at 12:41 PM -
Check inside the cabinet on the PSU (Power Supply Unit) to see if the green PIL is lit.
Also, on RJ3iB, there is a pushbutton on the front of the cabinet door. Sometimes that pushbutton needs to be cycled.
If the green PIL led is lit, that means the PSU is receiving adequate single phase AC power.
If the PIL is not lit, remove the PSU from the backplane and check the fuse on the inside. -
Thank you!
