Hello pro.
I have otc ax-c controller error E0051 encoder tranmistion failde. I was check wire of encoder, CNE1,CNE2 it is ok. Robot run but some time that error appear any time.
Please help me. Thank you.
AX-C robot error: E0051 encoder tranmition failed
Harryusjp -
December 6, 2016 at 9:56 AM -
This could be due to many reasons, you need to check one by one.
1. Fluctuation in primary power supply
2. Damaged encoder cable
3. Damaged encoder -
Hello sir.
I checked, every thing ok but when i change servo driver board UM221 it is work. but i donot understand, i have 4 robot and 4 robot same error (e0051 encoder tranmistion failure J4 axis).
thank a lot sir! -
1-) You should check the ground resistor.
(The ground resistor must be less than 100 ohm.)
2-) You should check primary voltage unit.
3-) You should use the ferromagnetic core for encoder cable.
(Controller and manipulator side)
4-) You should check the encoder voltage from the IPM Drive Unit.
(If this voltage is lower than 5.2V, replace the IPM Drive Unit)
