i am new in robots,
i have Kuka KRC 1.01
in the menu Configure -->I/O Driver reset there is message " No driver insatlled"
how to install driver for I/O card with cable X808.
in the robot there is MFC .
I need to work with digital input and output.
where to find driver or software to start i/o ports?
thank you
kuka I/O driver
boris_sh -
November 18, 2016 at 11:05 AM -
You have to find the file iosys.ini (located in KRC\Roboter\Init) This file can be reached through the menu also (IOconfiguration edit or something like that)
Open it and make sure these lines are not commented:Do the IO reconfigure after making any changes.
This should get MFC build in IO to work. I am not sure if you will see any drivers running.
Thank you
in the robot only c:\r1\programs
i will make roboter\init\iosys.ini but i dont know das it work -
Oh yeah. KRC1 with software 2.2.8 I am guessing ?
That will be robot\init\iosys.iniSame thing.
Post your iosys.ini here. -
Hi ,
I attached picture from display.
in navigator disk Archive is empty
i can't see iosys.ini
I cannot make file iosys.ini.
in the KRC only c:\R1\program
there isn't folder : INIT
the MFC have 2 connector X807 and x808
X807 work for safety, i make jumpers and robot is work
X808 is i/o module, but don't have signal /input or output/
sorry for my english
Thank you -
Looks like you need to login to expert mode.
That's why you do not see all other folders. -
Hi kr16_2,
I switch to expert mode and then i see c:\ d:\ e:\.....
Then i go to on I\O mode and i cofigured IOSYS.INI.
and this morning i read input and change output on X808.
I сав that there is interbus card but i don't have time for this workThank you very much
Thank you very much
Thank you very much
Thank you very much
