First, thank you for taking the time to read my post.
I'm not very professional.So , Please give me some more time.
I am attempting to use an ultrasonic sensor to control a DC motor using the PWM output of an arduino. Fairly simple, I know, but I'm just a beginner.
Here's my code, with an explanation of my theory and my error afterwards.
#define trigPin 7
#define echoPin 2
#define motorPin 9
void setup(){
Serial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(motorPin, OUTPUT);
void loop(){
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) /29.1;
if (distance <5)
analogWrite(motorPin, 0);
else if(5 <= distance <15)
analogWrite(motorPin, 50);
else if(15 <= distance <25)
analogWrite(motorPin, 100);
else if(25 <= distance < 35)
analogWrite(motorPin, 150);
else if(35 <= distance < 45)
analogWrite(motorPin, 200);
else if(45 <= distance)
analogWrite(motorPin, 255);
else;
Serial.print (distance);
Serial.println (" cm");
delay(500);
So, this is incredibly simple. I haven't yet begun differential drive nor braking, and soon I want to learn to change out the ultrasonic sensor programming with the NewPing library for more sensors and less delay.
Right now, I am hoping to have the arduino interpret the ultrasonic ping as a distance in centimeters and based of that distance set the DC motor to a defined speed. The PWM output goes to a 210 Ohm resistor connected to the base pin of a transistor, on the collector/emitter is the 18V circuit connected to the DC motor. On a separate circuit is the arduino and ultrasonic sensor. I was wondering if the component datasheets/part numbers would be helpful for you to solve my doubt. http://www.kynix.com/Detail/1128849/PMD9002D.html
The circuit successfully gives me accurate distances in the serial monitor window. However, the motor only goes at 100% speed. It does not throttle its speed regardless of the distance variable's value.
It startles me that the default motor speed for this setup is 100%, it makes me think the speed is acting digitally. I tried deleting the final elseif conditional for the distance being greater than 45 cm set speed at 100% and the circuit still powered the motor at 100%.
Any help would be greatly appreciated!
Regards
