Dear All,
I am making a network of two robots and a PC. Both the robots are connected via kuka service bus to a switch and then to a PC so that i can do WV configuration for both.Problem is that KSI IP is same for both the robots and in the network configuration from smartpad i can only change the ip of KLI ( as i think ).so is there any way to change the ip of KSI( kuka service interface).Both robots are of KSS 8.3
KSI IP
vivektronics2003 -
July 18, 2016 at 5:22 AM -
Dear All,
I am making a network of two robots and a PC. Both the robots are connected via kuka service bus to a switch and then to a PC so that i can do WV configuration for both.Problem is that KSI IP is same for both the robots and in the network configuration from smartpad i can only change the ip of KLI ( as i think ).so is there any way to change the ip of KSI( kuka service interface).Both robots are of KSS 8.3Hi Vivek,
I would suggest you to post your question in a new topic or any relevant topic in the forum. This is not the place where you should be posting your question as this topic is presenting us the guidelines to how to start a new topic in the forum. "Read First" doesn't mean that anyone will read your question first.
I hope you understand.
