Hi everybody. It's possible to run a karel program in BGL? I try to run an empty karel but without result.
Karel in BG logic
chrissiapla -
June 16, 2016 at 9:31 AM -
chrissiapla
You can't run karel program in BGL. You can run karel program parallel. Also you can use Karel options for running karel program automatically with start your robot controller.
Regards,
Scotty -
chrissiaplaYou can't run karel program in BGL. You can run karel program parallel. Also you can use Karel options for running karel program automatically with start your robot controller.
Regards,
Scotty
How to trigger a KAREL in parallel? -
In your case you can to use the Autoexecute.
This utility is: MENU -> NEXT -> SYSTEM -> Config -> autoexecute , just put your KAREL program there.Andrey.
Try using RUN instruction. It will work. In BG it will run parallel when an event starts but don't forget to check that it's finished before using RUN again.
