Hi! I want to explore the possibility to use IO-LINK for my IO Field Signals. Since I tend to use BECKHOFF ETHERCAT COUPLER EK1100 with IO terminals I foud that there is a EL6224 wich is a amster device. Don't know how to implement this guy into Work Visual for the configuration. Brobably it is not possible but configured with TwinCat (for Example) how it can be seen from the KRC4 BUS Extension? Is there any other way to use IO-LINK with KRC4?
ANYONE IMPLEMENTED IO-LINK FROM FIELD IO TO KRC4 CONTROLLER
IlFincoITA -
February 26, 2016 at 10:34 AM -
Hi IlFincoITA,
Have you been able to configure the EL6224 module with WorkVisual?
I am working on a similar issue:
https://www.robot-forum.com/robotforum/kuk…-in-workvisual/Thank you.
