Dear All,
I would like to write a program to draw a circle around the surface of a cone with a marker. Can someone guide me on the process to do it ?
Thank You,
Siddharth
Dear All,
Thank You,
Siddharth
Make an extra toolframe that extends to the centre of the cone, and rotate R 360 degrees.
Works ! I did it with glue.
Use a presure-limiter for the marker, otherwise it will wear out pretty fast.
Hi that worked.
So basically I could perform this operation by jogging in tool frame by pressing shift + Z(+-J6)
Could you tell me If i had to incorporate this motion into a program how would I do it? How do I write a line of code which does the above that is shift + Z(+-J6) starting from a point and ending at a certain point or stopping after certain time.
Kluk-Kluk do you have any examples of a pressure limiter product that you suggested?
