Has anyone tried out the new XMLRPC functionality with the new UR software release? I've been playing around with it a little bit, and it looks like a pretty cool feature. One issue I'm running into is passing any data that isn't pose data.
"An error occurred in the running program.
XMLRPC: Failed with error code -500: Unexpected error executing code for particular method, detected by Xmlrpc-c method registry code. Method did not fail; rather, it did not complete at all. map::at"
I've found that I can pack the data into a pose variable and then unpack it as needed, but it is a bit cumbersome. Anyone else run into this issue, or have a potential fix?
