is there anyway that I can program a pause that is connected to a door switch. instead of an e stop.
thanks in advance
door switch
chrisp -
August 14, 2015 at 1:19 PM -
I'm no expert but I might as well try help.
You could use a switch as an input signal, and I believe there are rapid commands to wait (pause everything) for durations.
In my mind the switch is open when the door is closed..
Hope that's worth somethingSent from my ASUS_T00F using Tapatalk
thanks in advancePlease check your X11 connector and its wiring diagram. It will show you how to connect a door switch to your robot.
Thank you for the input.
