I have a arcmate 100ic with a lincoln electric powerwave R500 power supply.
I want to be able to disable welding from an HMI.
I tried this...
If DI[1]=on, jmp lbl[1]
end
lbl[1]
$awepor[1].$arc_enable = 0
end
when I run this program, the weld indicator in the upper left corner of the pendant turns yellow, like it is off, but it will still weld.
When I go to the Test Cycle screen (pops up when I hit the WELD ENBL button) and run the program the status goes from TRUE to *****, instead of FALSE.
am i using the correct variable?
