Is it possible t import a tool (IGES or Step)in RoboDK ?
And attached it at robot?
Yes this is possible. STEP and IGES are supported CAD formats.
Follow these steps to convert an object into a tool:
1-Open the file in RoboDK (drag&drop to the main screen, or use File->Open)
2-Drag&drop the object item into the robot item (in the objects tree). The object will be automatically converted into a tool.
See the images below. The procedure is similar to RobotStudio.
Do not hesitate to let us know if you post in a forum:
info@robodk.com
For anyone reading this after the issue was solved...
The following tutorial shows how create a tool in RoboDK:
http://www.robodk.com/help.php#CreateTool
