hello guys
my system is already integrated with plc. but right now plc having some problem.robot is showing motion enable error. when i am trying to move . i want to bypass the motion enable input signal please tell me. it is krc4 controller
hello guys
Take a look at the system integrator manual.
Search for $MOVE_ENABLE.
During commissioning you could point this variable to $IN[1025] to avoid the need of a real signal.
This variable is part of the automatc external mode: configuration -> inputs outputs -> automatic external.
Good luck and good weekend.
The only way to bypass it is to connect this signal with a push button if you do not have PLC. But you will need to have a small IO rack at least which should be communicating with the Robot controller. Then you can connect a normally closed push button to this IO rack and use that Input in the Automatic External Configuration as Joan mentioned.
I hope your got the idea.
Good Luck.
