Hi Pros,
I read in the documentation about these I/O Ports, but what are they used for? Do they go to the SPS, or where, whats their job? Whats the difference between $DIN/$DOUT?
Greetings
FruitKiller
Hi Pros,
Greetings
FruitKiller
$FDIN and $FDOUT ports allow a program to access system signals as if they were digital I/O's. They are BOOLEAN values like ON or OFF (or TRUE or FALSE). You can find system signals like:
$FDIN[10] state selector on AUTO
$FDIN[17] DRIVE ON softkey
$FDIN[27] Enabling Device pressed
$FDOUT[22] U2 softkey higlighted
These signals are not for PLC communication.
$DIN and $DOUT ports are digital input or output signals. They are BOOLEAN values. You need to use IO_MAP configuration program to have digital I/O associated to $DIN and $DOUT. If you are using a C5G you can map:
discrete I/O from an I/O card plugged into a bus coupler
fieldbus I/O from a master or slave card plugged into bus coupler
and also the few I/O signals present on SDM board
For more info, read Programming Language and Control Unit Use manuals.
$FMI and $FMO are Flexible Multiple Ports, reserved to application programs. They are INTEGER values. They group bits into an INTEGER value, but with the advantage that the bits don't need to be contiguous.
e.g. in an automotive plant three bits were dedicated to select up to 8 program codes, but now programs need to become 10, and available spare bits are not contiguous... No problem, you map them adding into the $FMI you were using before. But in the past, this would have been a major headache, with plant wide ripercussions.
thanks much for your explanations !
Are the $FMI/FMOs also associated with this IO_MAP program? I assume the $FMIs are also comming from the PLC, since the program number is read from these.
Regarding to the IO_MAP: is that program related with this system variable $IO_STS ? Since I am working only with OLPs I dont have much knowledge about programs in physical devices.
Greetings
Fruit
IO_MAP works on three categories of I/O: digital, analog, flex. You will therefore use IO_MAP to configure $FMI/O's.
$IO_STS is not certainly one of the most used system software variables. Why do you want to use it?
PDL2 manual tells us: This predefined variable has a dynamic number of elements: it changes every I/O is compiled. If you map new I/O $IO_STS will change its content.
