I have a problem and hope You can help me. I needed to exchange a Servo pack SGDH-01AEOY 1 x 230 VAC 100W for Servo welding interface - SHWFU(XRC controller).There a difference between versions of old and new servopack.The old servo pack version is 0D214,a new version is 38A45.Acording instructions in document MRS6300GB.0.I.fm ,I try to set User constants
Pn 000 32 For servo slave wire feeder SHWFU
Pn 50A 8101 Hex Input signal selection
Pn 50B 6548 Hex Input signal selection
Pn 300 1000 Speed input rated gain (range 150 - 3000)0.01V / rated speed ESAB ARISTO
Pn 304 1600 Maximum output speed (rpm)
I Had problem with setting Pn 000 32( setting a digit 2 is imposible).In other servopack parameter Pn 000 is 20.I set parameter Pn 000 to 20. When starting controller I have alarm A.51 -It`s meaning: overspeed.Rotation speed of servomotor is excessively high.The servomotor running for a while and stop.I find manual for SGMBH,SGDH servopackThere is description of the alarm
A Servomotor wiring incorrect. Check and correct wiring. (Check for phase-U, -V, and -W wiring errors.)
B Position or speed reference input is too large.Lower the reference input values.
C Incorrect reference input gain settings. Check and correct parameter settings.
D Circuit board (1PWB) defective. Replace SERVOPACK.
I check A- the same wiring work with other servopack
My question is: What parameter(parameters) I have to exchange to adjust servopack. How I set Pn 000 - 32 If it`s the problem? Is it possible the new servopack circuit board is defective?
How I can proceed ?
servopack
zdravkov -
February 12, 2015 at 12:31 PM -
