I want to utilize the EE plug on our robots to fire some valves for a pneumatic gripper. Normally we just cut the cable at the back of the EE connector and wire in our own plug but I don't want to do this anymore. I found that numatics has a faunc specific end plate [url]http://www.numatics.com/Common/PDF/TDG22FNDS2-0EN.pdf/url] and this would be the perfect solution for what I need except that it does not match up to the pinout for our robots. After many phone calls and searching I am lost. What do most of you do with the EE plug? Do you just buy a cable and cut the end off of it then terminate it into a junction box? Is there no pre-made junction boxes out there? Or other plug and play/ready made valve manifold solutions?
Fanuc 430iw/rj3 EE Plug, Whats out there?
Harleydude -
January 20, 2015 at 9:07 PM -
Thread is Resolved
I always get just a bare EE plug and solder up whatever I need to it. I then terminate it into a hoffman box on the arm somewhere with a terminal strip mounted inside. Easy as pie. You just have to understand that some robots are sourcing outputs, while other older ones are sinking.
Thats pretty much what we normally do but I was hoping someone out there made something similar to the numatics fanuc endplate.
