Anybody know why 2400L's are not listed as wall mountable?? Just the 2400/10. I might try it anyway..
2400 L Wall mounting
olddog71 -
December 5, 2014 at 11:07 PM -
I don't remember why, but a few things to consider is that depending on the age of the unit the wall mounted robots have a different motor for Axis 1.
There was also some limitations on Ax 1 movement, you can't do a full +/- 180, it's more like +/- 30. -
Thanks for the reply! I hung it up there and it works ok. Like you said, you need to limit the travel in axis 1 or it can get in a position which it can't drive itself out of due to the weight of the arm. Wall mounting is a nice set up for our Waterjet cutting applications, You really get a nice working area and for flat boards being cut perpendicular to the mounting position you can do a lot of manipulations without using axis 4. Thanks again! Cheers
