Hello all,
I need to add two robots (KRC4) to a windows domain.
I've found it in the documentation but still have not tried it...
How should I do it?
Is there any documentation out there depicting the steps?
I need to specify in each robot:
- IP address ==> done
- network mask ==> done
- default gateway
- primary and secondary Wins
- primary and secondary DNS
I know the recommendation is not to update the information on the network card from Windows, but can I do that from the KSS?
And then I do need to make the right steps in windows.
Now that I've found it, I can see how the manuals recommend changing the "Real- time OS Virtual Network Adapter"... is that right? is this one the one that must be updated?
Thank you all in advance!
