Hi
I have LRMate 200ic robot with R30ia controller I wrote karel program in olpc software then convert to .pc file and loaded in controller . How can i open this file and executed that ?
thanks
Karel program
ELECOMP -
November 17, 2014 at 7:02 AM -
Hi
Press "Select" and find your .pc program. If you not found in list her, then you need press detail and added to show the Karel program. And after if all is alright you can find and select your program.Added : if you cannot find Karel program. Please check is enable karel( $KAREL_ENB) on your robot controller!
Regards,
Scotty -
Thanks scotty
I found the .pc program but I can,t open .pc program and run it . when i select the program , Invalid program selection error appear top of the teach pendant . and in Detail section I can,t change any things .
please help me step by step -
Okay. Lets together try it. Can you say what are you doing for downloading the pc files. And can you wrote what you have recieved from compiler after compile your program.
Regards,
Scotty -
hi
I wrote the karel program in olpc software and compile to the .pc file and load to controller with USB port on teach pendant . now i want to open this file and executed that .
thanks -
Compiler after compile write "Translation success"?? Check please system variable $KAREL_ENB, if it no "enabled" You need set it. And can you please say code of error when you try select it.
Regards,
Scotty -
I can execute the karel program but i can,t see structure of program .
How can see karel program in teach pendant ? -
hmm...sorry but you cannot see the karel program on TP. It is one of bad sides Karel program. You must to know what doing selected program.
thanks scotty
You don´t see program but the variables you see.
Select your Karel program->enter-> Press data ->F1->select Karel vars. In variables, you'll see if program works.
