I was delegated to Maintain the FANUC P-100 robot after our Maintenance guy just wlked off the job . I am new to this i am a Vacuum Tech. How would i replace the Battery holders that are inside the panels that house the boards without losing the cmos and Robot Programs.
How do I replace D Battery holders without losing program memory FANUC P-100
agentflees -
November 5, 2014 at 10:45 AM -
what controller? normally, you just switch the controller on, change the batteries and voila. not sure if that's the same with painting robots.
Hi Agentflees
We have RJ3 and R30 controllers at plant an the procedure is the same....keep the robot controller on and replace the batteries, after battery replacement a error message appear at pendant....BBALARM.....just reset....
Now if you mean that your battery holder is damaged...should be the same....2 cables with 2 screws....just keep the controller on during replacing that.....
Regards
AGENTFLEES is not referring to the robot's D batteries. He is referring to the D batteries that are inside of the robot controller cabinet. I believe he has an RH controller.
AGENTFLEES, what type of controller do you have?
