Is there a way I can keep some of the vision offsets in the VR from changing, or assign them a value before the point is offset?
When I set up a vision process different parts seem to adjust the angle which makes a big difference where my wire goes in the weld joint. If I only keep the X Y offsets I'm where I want to be.
I want to prevent the torch from rolling in any direction.
Thank you.
