repaired cpu after disaster loaded all software back in and cant find the section to look and change it to work with 455 welder anolog v 4.21-1
seems to be working as general mig and i need alu pulse to work
has anyone set one up before?
thansk tom
thansk tom
zarmock: set up the R-J2 as Lincoln + PW450. The analog interface box takes care of signal emulation. The robot is non-the-wiser that is is communicating to a digital machine. Than you can use the toggle switches on the front of the machine to setup for Al pulse / gas / wire size etc.
is this done in control start or in setup ?
Yes from a controlled start. Once setup as Lincon PW450 start cold. Then make sure your IO is configured. Some of it becomes uninitialized.
