how to change read only system variable ($SCR.$SFRUNOVLIM).
W want to move faster on T2 mode.
change system variable
22deg -
June 26, 2014 at 11:44 AM -
You can change it in a controlled start.
How to do it?
What controller do you have?
You can also create it in a TP program and execute it for some system variables that are write protect. Use the register instruction, select *=*, select param name, type the system variable, on the other side of the = make it a constant and type in your value.
OR go to the system variables in a controlled start.
