hi;
I want my line to collect data IRC5 robots. how much time for changing shifts worked, how much time for it to have stopped... Can I use the duty time counter output? Do you have another suggestion??
thanks...
about duty time counter
metintataroglu -
June 13, 2014 at 11:05 AM -
Use the run/arm power on contactor?, would tell you how long the robot is moving.
robot model is IRC5. There are approximately 10 routine. like this, how much work does in which routine, or did not expect how much. I need to do an edit. but in this case the robot stops when working on any routine will continue to count the time because I believe there will be problems in this regulation
