Hi, Need some suggestions I have a S3 here and it gives me the same problem. When the robot is in manual and you try to operate it it gives you an error that says that its in auto. My first thought was the key switch but when I changed it, it did the same thing. I then swapped it out with another controller and just kept the CPU and still gave me the same error. I then swapped the CPU back and the error still stayed. any ideas????
S3 Auto/Manual problem
JoCo439 -
May 22, 2014 at 3:17 PM -
Dear joco
Before CPU you should replace DSQC256 system board. Because Key switch signals is evaluated via this board.
Sent from my LT29i using Tapatalk
What is the exact error message displayed including error number?
Hey hey. I fixed it I had to change the CPU and the safety card for the signal for the brake relies wasn't there. Thanks for your help!!!!
