Has anyone used the FANUC robot RJ3 the LOAD function in System Master / Cal menu? Did some testing, I removed the battery and turned off the controller. Mastering the robot out of the marks, then used the LOAD function and loaded values SYSMAST.SV file, the robot returned with all axes for brands. But repeating this procedure as many times around an axis outside brands, usually the axis 1, 4 or 6.
If anyone has any info, thank you.
