KAREL unit testing framework
  • jay
  • March 1, 2014 at 5:19 PM
  • jay
    25
    82
    Hey everyone,
    Just wanted to quickly share an open source project I've been working on: KUnit, a unit testing framework for KAREL. It provides some simple structures and assertions for writing automated unit tests on the controller.
    I wrote a blog post about it here: Introducing KUnit
    You can download and view the source code on GitHub: https://github.com/onerobotics/KUnit/
    It basically allows you to write small tests/assertions about your KAREL code and then use a web browser to see the test output.
    Example:
    PROGRAM test_add_int
      -- %NOLOCKGROUP is required to run KAREL from browser
      %NOLOCKGROUP
      -- %INCLUDE the KUnit routines
      %INCLUDE kunit.h
      -- the ROUTINE under test
      ROUTINE add_int(l : INTEGER; r : INTEGER) : INTEGER
      BEGIN
        RETURN(l + r)
      END add_int
      -- 1 + 1 = 2
      ROUTINE test_11 : BOOLEAN
      BEGIN
        RETURN(kunit_eq_int(2, add_int(1,1)))
      END test_11
      -- 2 + 2 = 4
      ROUTINE test_22 : BOOLEAN
      BEGIN
        RETURN(kunit_eq_int(4, add_int(2,2)))
      END test_22
      -- 0 + 0 = 0
      ROUTINE test_00 : BOOLEAN
      BEGIN
        RETURN(kunit_eq_int(0, add_int(0,0)))
      END test_00
      BEGIN
        -- initialize KUnit
        kunit_init
        -- do some tests
        kunit_test('1+1=2', test_11)
        kunit_test('2+2=4', test_22)
        kunit_test('0+0=0', test_00)
        -- output the test suite results
        kunit_output
      END test_add_int
    Run the program in the browser via http://robot.ip.address/KAREL/test_add_int and see:
    KUnit
    Finished in 0.002 seconds
    1500.0 tests/sec, 1500.0 assertions/sec
    3 tests, 3 assertions, 0 failures
    Give it a shot and let me know if you have any questions, issues, feedback, feature requests, etc. Pull requests gladly accepted :smiling_face:
    ONE Robotics Company
    Edited once, last by jay (March 1, 2014 at 7:30 PM).
