Hi team!,
I am new on forum, but I have a question?, I need to do a backup for PAC Numbers and System Variables,
Do you help me to do it?
Hi team!,
Please tell me what robot and controller model.
SAME PROBLEM R2000IB-165F AND R30ia controller.
As far as I know there is no need to backup PAC codes. They are present in the software load media and once the option is installed you would then save the option via an all files back up or an image. You should do both.
If you have purchased an option and then installed it after entering the PAC code the same would apply.
SO for the R30iA models (see the teach pendant pic)
menu, 7(file). the backup device will be shown in the upper left. in this case it's MC or memory card. to change it press F5 (util) and select set device and then select the preferred device from the drop down list.
then press F4 back up and select all of the above.
after that press F4 and select image.
Make sure the teach pendant is turned on
OK, thanks for the info!
Thanks a lot for your help, I think the same about the backups, just I think the user understand in different way...
Anyway, thanks again.
