Into Standalone section "DU module only, or no ABB manipulator" is set.
Bleeder was changed to HW version.
34266 Rectifier inrush limitation and bleeder active In drive module 1, with rectifier unit at drive unit position 1, the inrush control resistor is active at the same time as the bleeder resistor is active.The inrush control resistor is located in the rectifier unit.The bleeder resistor is connected to the rectifier unit or the drive unit with embedded rectifier
When used IRB460 Drive mod. key err. mesage is out, but wrong pwm parameters for Yasgawa mot. is present.
I gather: Drive module for Standalone "don't know" 400VAC input.
Was installed:
Rob W. 5.15.02, Additional options, Standalone controller.
RW Drive module 1 key: Drive module only or No IRB manipulator, Drive System 09 2600/4400/6400R <- must be 09 460/4600/66xx
