Dear all,
Is it possible to use RSI ethernet and Ethernet KRL together in the same program? If it is possible, what will be the IP seting for both? Same IP different port or different IP?
Thank you
Dear all,
Thank you
I honestly don't know -- I've never seen it done. If someone *did* do such a thing, the IP address for both would probably be the same -- they would have to share either the Realtime Ethernet card, or the KUKA-Router to the motherboard Ethernet card. Different ports would probably be required to prevent conflicts.
At least, under KRC2. I'm not sure how a KRC4 might play this.
Unless the EKX traffic was heavy, the RKX could probably the additional bus traffic without any serious issues. The big problem is, would KSS allow those two Tech Packages to coexist?
