Can anyone help mr to record Home position & to get ATPERCh signal in RH controller..
ATPERCH in RH controller
mani_mech031 -
July 22, 2013 at 7:09 AM -
- Move to your desired HOME position.
- Menu -> SETUP -> REF POSN
- Record your position
- Don't forget to set a value in the right colum (for example 2) otherwise if your robot is not for 100% at your HOME position the AT PERCH signal is not set.Now you should have the AT PERCH signal if your robot is at the Reference position you recorded.
Hello Mr. StijnM,
The procedure which was mentioned works only for RJ series controllers.
The RH/RG series the same procedure will not work.
We are also working on the same issue. -
I'm sorry, I read the post not correctly.
Wish you luck finding a sollution.
Have a nice weekend. -
still i didnt got the solution,can some one help me...
Hi guys, I take it that your also programming these in KAREL ?
There is a way to write some code that will check if your near a known position, and then turn on an output. Works like a reference position.
