Hello, I have a problem regarding the weave pattern after a fault followed by retrying. Whenever it gets stopped by arc supervision, the robot retries that arc motion but It doesn't do weaving untill the next command. It follows a straight line while welding and continues weaving with the next arcL command. Can it be fixed?
S4C Plus Weaving
neyzencefil -
May 23, 2013 at 11:11 AM -
Any ideas =)? Can it be maybe because it was not intended to continue weaving until the next command. To explain the problem more briefly: If there is an arcL command with weaving which welds a line of 100 mm and the arc supervision halts the command after 60mm due to a problem that is caused by the welding parameters, it retries and continues welding but welds the remaining 40mms without weaving.
