Hi Gang, I have a robot that im preparing to modify the program on. I always make backups before I modify anything on customer robots so if things go bad, they can recover to exactly where it was before I arrived. I have a problem and cannot figure out a solution. I cannot get the controller to give up a copy of the PC files it uses as the main program. With the program aborted, even with the TP switch turned 'on', when I goto the select screen , highlight the program.pc file.. i cannot get it to 'save as' or 'copy' to any external source. It says invalid program selected on the TP screen. I made a controller backup from a controlled start but it looks like the operating system and also did not export my programs. When I do a backup 'all the above' it once again will copy out the frame vars etc..even the TPE programs, but not the PC files. They are not protected and are also not running as any background tasks.
Any suggestions? I cannot make any code changes for the customer till I get this backup.
Thanks -Eric
