I'm using the RSI 3.1.
By using the ethernet object, can I transfer data from PC to KRC and save it in a variable?
KRC 4 RSI3.1
omaxio -
January 4, 2013 at 10:23 AM -
Can you give a little more clarification of your objectives?
It is possible to set up the ethernet object so that some known variables are passed from the PC to the controller and vice-versa, but it is quite limited in it's scope.
If you want to be able to set controller variables from an external PC in a more freeform manner, then you will need a different solution. -
Can you give a little more clarification of your objectives?It is possible to set up the ethernet object so that some known variables are passed from the PC to the controller and vice-versa, but it is quite limited in it's scope.
If you want to be able to set controller variables from an external PC in a more freeform manner, then you will need a different solution.Thanks for your reply. I've already got the solution.
