[size=36pt]Dear sir,
i need program example or program hint for COMBINATION OF DE-STACKING AND PALATALIZING FOR 4 LAYER, 3ROW 3COLUMN BOX. the workpiece shape is circle. in the dia of 190mm. Kindly hint me for this process.[/size]
NEED COMBINATION OF DE STACKING AND PALATALIZING FOR 4 LAYER, 3ROW 3COLUMN BOX
Vinoth Shivan -
March 16, 2019 at 7:27 AM -
What do you want the process of destacking to look like? Are you trying to remove a single layer from all 9 positions then move to the next layer and repeat or destack a single position then index to the next position and start the destacking over?
Those are two different programs
Sent from my iPhone using Tapatalk
Am trying to remove a single layer from all 9 positions then move to the next layer.
Dear sir,
Kindly attach both program examples.Thanks &Regards
Vinoth K -
Try to follow this logicIf X < 3
X=X+1
Else
X = 0
If Y < 3
Y = Y+1
Else
Y = 0
If Z <4
Z = Z+1
Else
Z=0
EndIf
EndIf
EndIfWith that you pass 1 by 1 each position.
I hope I helped
