Greeting,
(My English spelling is bad, I use google translate, sorry)
I have few questions, I hope someone help, because I already almost mad ...
It is the ABB IRB 1500 S3.
The problem is with the wire feeder, inability mauel feed wires.
The problem is the lack of analog output 2 voltage to DSQC224 plate.
The voltage used to appear and function normally when the system start (output 8 active, 8 input active) (approx 3-5V), and after the command CLEAR voltage disappears. Also voltage is sometimes not appear at system startup, there is no rule.
Voltage appears once by activating the "MANUAL WIRE" on the A351 module, and then move the wire, but sometimes not, especially when you do restart the system (without changing any settings in a software system)
I was confused because I do not understand the "REGISTER" and how they can bring value to know whether the analog output is correct or board is bad.
I'm not a programmer, I am electronics technician, and my job is to set all physical functions for the correct operation of the robot, while the programming performed trained programmer.
So specific questions, I hope you help:
What function "REGISTER" in the "MENU" (or FUNCTION MENU)?
As in the "REGISTER" to send a command to increase the voltage on the ANALOG OUT 2 (regulation of wire speed, reference voltage which is sent to A351)
I controlled the entire wiring, complete A351 hardware OK, the presence of the supply voltage according to service manual, and all will be normal.
Thus, there remains a suspicion of irregularity panel DSQC224 or my ignorance of how to send a command to increase the voltage on the (analog output 2).
I also noticed that I never got any power "ANALOG OUT1" (control voltage welding) and if the weld parameters are set.
We have all the necessary documentation, but I can not conclude that you have a defective plate 224 or my fault in the setting.
Thank you in advance for your help!
