Hi! This is the first time that i use Ethernet/IP on COMAU. We bought the BUS predisposition with X20 Master Module and relative cabing. Now we want to put in a different case our bunc of Digital I/O. Does anyone know if the BECHKOFF module BK9105 is suitable for this purpose? Is there something to pay attention for?
CONTROLLER C5G AND ETHERNET/IP
IlFincoITA -
June 12, 2015 at 12:05 PM -
OK here the thing. On powerlink BUS we have a B&R X20IF10D3-1 Ethernet/IP adapter. It has to be connected to a BECKHOFF Ethernet/IP coupler. The BK9105. I know the BK9105 IP wich is 172.16.17.3 and its Subnet Mask 255.255.0.0 I know also its image process map that is of 3 Inputs WORDS and 3 Outputs WORDS.
Now on C5G controller on IO_CNFG I have the device X20BC1083 on address 129, I press fildbut and I have added my B&R X20IF10D3-1 Ethernet/IP adapter, then I've pressed configure.
There is a page with:
Name: I've entered one
IP: I've entered the IP 172.16.17.3 of the device
Subnet Mask: I've entered 255.255.0.0
I/O: I've entered 64+64 (because the image process is of 3WORDS+3WORDS
System Profile: I've flagged it because a need to assign bits for "DRIVE ON" ports and so onNow the B&R Module do not communicates, it has some RED LED
I've looked into I/O on the panel and on that device I've a Red Cross over it and If I pressed properties it says "not connected"Is there any advice?
