Does anyone know if its possible to write protect position registers and registers? Rj2 controller.
Thx
Thx
there should be a pass word level for that. fortunately I've never had to assign passwords so I'm not that keen on the different levels of password accessibility .
I would be interrested too in this fonction, does anyone know how to do it?
Thank you
you can lock and unlock Position registers.
May be you can lock registers as well.
If so try it in BG logic.
F1 (Inst) -> LOCK PREG.
Insert LOCK before the Position Registers you want to lock, insert UNLOCK when passed the Position Registers you want to lock.
Good luck.
Thank you for your answer.
I forgot to say it is an RJ controller.
Is there a similar fonction for RJ controller because i can't see LOCK PREG uder insert .
Thank you
