I am trying to troubleshoot an issue that is coming up when the PLC is trying to send data to the KRC. Any help would be greatly appreciated!
Info:
The robot is the slave to the PLC. There is Ethernet communication between the PLC and KRC, and DeviceNet between the KRC and a Turck DNET module which controls the gripper open/close functions. The Ethernet data size is 128 bits, and the devicenet size is 16 bits. I have assigned the first 16 bits of the KRC communications data table to devicenet and 33 to 161 for the PLC to KRC comms (16 to 32 bits being a buffer zone I guess).
I have the KRC ethernet card correctly set up as well as the generic ethernet module present in the PLC. The assembly instances and data size are good on the PLC side.
When the PLC goes online, the generic module on the PLC shows it is talking to the KRC without error. However, on the KRC teach pendant the error 'EIP Device 0 in idle mode' and "Error Reading Ethlpdrv driver' pops up.
On the pendent, I am able to change the data values of the DeviceNet outputs however I cannot change any data values that are shared between the PLC and the Robot.
Please see below for the information I have entered to set this system up:
PLC is Allen Bradley 1769-L32E
Taken From the am.ini:
[Archive]
Name=u:\archive.zip\
Config=All
DiskNo=0
LastDisk=1
ID=38498b2e-77b5-425d-b794-bd679404e1af
Date=2012-01-17_09-56-38
[Roboter]
RobName=KR210-2
IRSerialNr=922112
[Version]
Version=V5.6.8
[TechPacks]
TechPacks=EtherNet/IP|
EtherNet/IP=V2.1.0
Taken from the IOSYS.ini:
[CONFIG]
VERSION=2.00
[DRIVERS]
ETHERNETIP=23,eipInit,eipdrv.o
;CNKE2=21,cnke2CPInit,cnke2drv.o
;DNSC6=20,dnsc6Init,dnsc6drv.o
;DNSC5=19,dnsc5Init,dnsc5drv.o
;DNSC4=18,dnsc4Init,dnsc4drv.o
;DNSC3=17,dnsc3Init,dnsc3drv.o
;CNKE1=16,cnke1CPInit,cnke1drv.o
;INTERBUSPCI=15,ibsCPPciInit,ibpcidrv.o
;DSEIO=14,dseIoInit,dseiodrv.o
;DNSC2=13,dnsc2Init,dnsc2drv.o
;DNSC1=12,dnsc1Init,dnsc1drv.o
;PBMASL=11,pbmsInit,pfbmsdrv.o
DEVNET=2,dnInit,dn2drv.o
;INTERBUS=1,ibusInit,ibusdrv.o
;MFC=0,mfcEntry,mfcdrv.o
[ETHERNETIP]
inb4=0,0,x16 ;$in[33] to $in[161]
outb4=0,0,x16 ;$out[33] to $out[161]
[DEVNET]
$inb0=5,0,x2 ;0 to 16
$outb0=5,0,x2 ;0 to 16
I have much more information so please ask if you feel that it would help. I am in contact with 2 KUKA techs but they are stumped and unable to work on this machine without traveling a far distance.
Any help is greatly appreciated!!!
