Setting a variable only after the motion primitive has finished without losing the advance pointer
  • Mathias314
  • June 10, 2025 at 3:06 PM
  • Mathias314
    • New
    Hello everyone,
    I am using the KUKA ready2educate cell with the following setup:
    Controller: KRC4 compact - 8.3.36
    Robot: KR3R540 C4SR
    I want to write the command id of amotion primitive into a variable after the primitive ptp/lin/circ execution is finished. Does anyone know a way to implement this without losing the advance pointer?
     loop
          if get_command(current_command) then
             CURRENT_COMMAND_ID = current_command.id
             switch current_command.type
                case 1
                   check_error(do_grip(current_command.grip_data))
                   check_error(do_move(current_command.step, current_command.move_data, current_command.id))
                   ;LAST_FINISHED_MOVE_ID = current_command.id
                case 2
                   ;msgnotify("Motion primitive with command ID %1 done","Motion EKI",current_command.id)
                case 3
             endswitch
          else
             CURRENT_COMMAND_ID = 0
          endif
       endloop
       close_interface()
    end
    deffct int do_move(step :in, move_data :in, cmd_id :in)
       decl int step
       decl move_type move_data
       decl int cmd_id
       decl int error_code
       error_code = 0
       switch (move_data.mode)
          case 1
             set_joint_vel(move_data.velocity)
             set_joint_acc(move_data.acceleration)
             set_blending(move_data.blending)
             INTERRUPT ON 19   ; enable interrupt to stop movement
             ptp move_data.joint c_ptp C_DIS
             INTERRUPT OFF 19
             LAST_FINISHED_MOVE_ID = cmd_id  ; save id of last finished motion primitive
          case 2
             INTERRUPT ON 19
             ptp move_data.cartesian c_ptp C_DIS
             INTERRUPT OFF 19
          case 3
             set_cart_vel(move_data.velocity)
             set_cart_acc(move_data.acceleration)
             INTERRUPT ON 19
             lin move_data.cartesian C_DIS
             INTERRUPT OFF 19
          case 6
             INTERRUPT ON 19
             circ move_data.cartesian_aux, move_data.cartesian C_DIS
             INTERRUPT OFF 19
       endswitch
       return error_code
    endfct
    I would appreciate any hints or suggestions on this.
    Thanks in advance!
    SkyeFire
    1,051
    9,424
    • June 10, 2025 at 4:00 PM
    • New
    There are multiple places in that code where the ARP may get broken, depending on whether CURRENT_COMMAND_ID, LAST_MOVE_COMPLETED, etc are variables or Outputs.
    Generally the simplest way to set Outputs without breaking the ARP is to use TRIGGER commands.
  • Mathias314
    • June 10, 2025 at 4:53 PM
    • New
    Thanks for the hint. CURRENT_COMMAND_ID and LAST_FINISHED_MOVE_ID are Variables that are send as feedback via eki.
    Do you have a code snipped or a source on how to use the TRIGGER commands to set LAST_FINISHED_MOVE_ID after the move is completed?
    Thanks in advance!
    Edited once, last by Mathias314 (June 10, 2025 at 5:41 PM).
  • Fubini
    278
    1,886
    • June 10, 2025 at 5:01 PM
    • New
    Can easily be found by looking into system integrators manual or searching in this forum with keyword trigger.
    SkyeFire
    1,051
    9,424
    • June 10, 2025 at 5:40 PM
    • New
    Quote from Mathias314
    Thanks for the hint. CURRENT_COMMAND_ID, LAST_FINISHED_MOVE_ID and are Variables that are send as feedback via eki
    How are you doing the EKI operations? Those break the ARP as well, unless you're handling your EKI in Interrupts or the SPS.
    TRIGGERs with approximated motions have a complex set of options. Simplest TRIGGER is usually something like:
    TRIGGER WHEN DISTANCE=0 DELAY=100 DO $OUT[3]=TRUE
    TRIGGER WHEN DISTANCE=0 DELAY=101 DO vtcom_setup(1,2) PRIO=-1
    PTP XP1 C_PTP
    Setting an output, or calling a subroutine. TRIGGERs are always "attached" to the next motion command, regardless of the logic between the TRIGGER and that motion. So it's possible to "stack" multiple TRIGGERS on one motion, up to a limit (7? 10?).
    DISTANCE=0 "attaches" the TRIGGER to the start of the motion. DISTANCE=1 attaches to the "end" of the motion, or (if the motion is Continuous), to the "closest approach" -- basically, where the approximated arc passes closest to the programmed point. This is where the path planner switches between the current motion and the next motion.
    DELAY=xx is a delay in milliseconds. It can also be negative, to fire the TRIGGER in advance of the physical location. Note: if the DELAY puts the TRIGGER more than 50% of the distance between two points, the TRIGGER fires at the 50% mark.
    PRIO=-1 is a way of letting the system choose a Priority level automatically. -1 is the best choice, usually.
    TRIGGERs are special types of INTERRUPT, and use the same resources, so the limit on the maximum number of "armed" INTERRUPTs or TRIGGERs is the sum of both. They also use the same Priority levels, which is another reason to use PRIO=-1 for TRIGGERs.
  • Mathias314
    • June 10, 2025 at 7:19 PM
    • New
    Thank you very much for your help:)
    With this approach, however, another problem arises: the trigger function can only accept global or constant variables.
    I receive motion primitives via EKI (in an interrupt). I execute these in a switch-case statement. I want to send feedback via EKI (also in an interrupt) indicating which primitive (ID) has been completed. To do this, I need to read the ID of the primitive at runtime and then set it once the primitive has been processed.
    If I understand correctly, I cannot pass the variable in this way in the trigger function.
    This was my approche:
       decl int step
       decl int cmd_id
       decl int error_code
       error_code = 0
          case 1
             TRIGGER WHEN DISTANCE=1 DELAY=100 DO set_cmd_id_done(cmd_id) PRIO=-1
             INTERRUPT OFF 19
       endswitch
       return error_code
    endfct
    def set_cmd_id_done(cmd_id :in)
       decl int cmd_id
       msgnotify("Command with ID %1 done","Motion EKI",cmd_id)
    end
    Is there a solution or workaround for this?
    Edited once, last by Mathias314 (June 10, 2025 at 7:24 PM).
    SkyeFire
    1,051
    9,424
    • June 10, 2025 at 8:48 PM
    • New
    Wait... I don't recall that being a TRIGGER limitation (then again, I'm old). As long as the variable is both DECL'd and Initialized before the TRIGGER fires, any type of variable should be okay. What kind of error did you get when you tried this?
    I take it CMD_ID was the variable that caused the issue? That looks like it should be fine, as it's a received argument, so there shouldn't be any time where the TRIGGER fires with that variable in an unitialized state.
    If the DECL location of the variable really is a problem for the TRIGGER, then it should be easy to fix this simply by adding a static variable (DECL it in the module's .DAT file with DECL INT myIntVar=0), and then copy CMD_ID to it at the top of the SWITCH.
    Oh... wait. Maybe it's the DELAY value. I can't see the entirety of DO_MOVE, but the way it's contructed suggests that the DELAY could push the actual firing of the TRIGGER out to a time when the program pointer has already returned from DO_MOVE. KRL has a single-line execution time down in the several-nanosecond range on modern KSS versions, for non-blocking commands. That could cause a bad interaction, with the memory space allocated for CMD_ID having already been deallocated. Copying CMD_ID to a static .DAT variable would probably still fix it, but you can test this theory by simply changing the DELAY value to 0 or even -100 and re-testing.
  • Mathias314
    • June 11, 2025 at 12:17 PM
    • New
    I received the error: "Use of runtime data not permitted." ("Verwendung von Laufzeitdaten nicht zulässig")
    I tested the implementation with a delay of 0 and -100, and I still got the same error.
    Introducing an additional variable that is declared in the .dat file worked.
       decl int step
       decl int cmd_id
       decl int error_code
       error_code = 0
       temp_cmd_id = cmd_id
          case 1
             TRIGGER WHEN DISTANCE=1 DELAY=0 DO set_cmd_id_done(temp_cmd_id) PRIO=-1 ; save id of last finished motion primitive
             INTERRUPT OFF 19
       endswitch
       return error_code
    endfct
    Thanks for your help. Its great having people like you in the internet:)
    But I don’t quite understand why this approach works, and why the temp_cmd_id variable declared in the .dat file isn’t overwritten with future values, like I experienced with the previous issue?
    SkyeFire
    1,051
    9,424
    • June 11, 2025 at 5:05 PM
    • New
    Huh! I'll be dipped. I honestly can't recall ever running into that, but I'd have to deep-dive my archives to see if I ever had a similar TRIGGER setup.
    That's a good question -- when I made that suggestion, I wasn't thinking about how do_move() is being called from a loop.
    Unfortunately, I don't have a good answer. If you're seeing continuous motion between points with this program, the ARP is obviously not being broken. But that seems like it should be having "future" values overwrite the .DAT variable.
    It may be that KSS handling of sequential calls is invisibly handling this for us, but that's just a guess.
    panic mode
    1,280
    13,079
    • June 11, 2025 at 5:19 PM
    • New
    you cannot pass runtime variables as parameters to ISR. also they must be initialized before advance run pointer reaches the interrupt or trigger instruction.
    usual workaround is to move declaration of such variables to a DAT file
