Kuka Found mismatched set of tokens.
  • Ryno
  • June 9, 2025 at 4:38 PM
  • Ryno
    70
    • New
    Good afternoon, I want to rewrite the program from krc2 to krc4. There are a lot of errors, but this is the first time I've seen this one. How does it work? Who knows?
    Images
      • 315.24 kB
      • 864 × 1,920
      • 15
    SkyeFire
    1,052
    9,429
    • June 9, 2025 at 5:25 PM
    • New
    KRC2? What KSS version?
    KRC4? What KSS version?
    The IMPORT commands are, as far as I know, no longer used under KSS 8.x. They weren't used under KSS 5.x either, but were tolerated as a holdover from old KRC1 programs from KSS 2.x, to the best of my knowledge.
    The purpose IMPORT once served is now handled by using GLOBAL Declarations.
  • Ryno
    70
    • June 9, 2025 at 6:55 PM
    • New
    Good afternoon. krc2 v5.5 and krc4 kss 8.6 kuka officelite
  • MOM
    175
    7
    1,424
    • June 9, 2025 at 7:25 PM
    • New
    On KSS 5.5 IMPORT exists. On KSS 8.x IMPORT is removed.
    Quote from SkyeFire
  • Ryno
    70
    • June 9, 2025 at 7:42 PM
    • New
    Foto
    Images
      • 356.31 kB
      • 864 × 1,920
      • 10
  • Ryno
    70
    • June 9, 2025 at 7:44 PM
    • New
    Foto
    Images
      • 370.03 kB
      • 1,200 × 1,600
      • 8
  • Ryno
    70
    • June 9, 2025 at 8:40 PM
    • New
    Can you tell me how to create a program correctly without using the import function?
    SkyeFire
    1,052
    9,429
    • June 9, 2025 at 9:11 PM
    • New
    Quote from Ryno
    You will need to make a list of every item the old program is IMPORTing. In the screenshots you provided, it appears to only be variables, but IMPORTing subroutines and functions was also done.
    For variables, the simplest way to make them Global is to DECL them in the module $CONFIG.DAT. Any variable DECL'd in CONFIG.DAT is inherently Global, dating back to the earliest versions of KSS.
    However, tampering with $CONFIG.DAT, while legal, is not the best way to do things. An alternate method would be to create a new .DAT file, DEF'd with the PUBLIC keyword, then DECL GLOBAL each variable. This is part of the KUKA ConveyorGlobals .DAT file as an example:
    DEFDAT  conveyorglobals PUBLIC
    ;FOLD CONVEYOR GLOBALS
    ;CONV Booleans
    DECL GLOBAL BOOL B_CALL_CONV_MOV=TRUE
    DECL GLOBAL BOOL B_QUIT_BECAUSE_MAX_DIST=TRUE
    DECL GLOBAL BOOL B_QUIT_BECAUSE_EMS=FALSE
    DECL GLOBAL BOOL B_CONTINUE_AFTER_EMS=FALSE
    ; many more variables here
    ENDDAT
    Every variable in a PUBLIC .DAT file that is DECL GLOBAL becomes Global across the entire KRC, available to any routine in any module.
    HOWEVER: this creates the potential to have "local" variables and Global variables that have the same name. This usually creates a Warning in WorkVisual, but does not generate a compilation error. So it is your responsibility to ensure no name collisions occur.
  • Ryno
    70
    • June 9, 2025 at 10:18 PM
    • New
    Quote from SkyeFire
    ;CONV Booleans
    ENDDAT
    Thank you so much for your reply! Tomorrow I'll try to do as you said.
  • Ryno
    70
    • June 11, 2025 at 5:27 AM
    • New
    Quote from SkyeFire
    ;CONV Booleans
    ENDDAT
    The main program uses a subroutine in which these problem points are used. It is quite clear to me how to register them in the main program.
    Images
      • 370.03 kB
      • 1,200 × 1,600
      • 3
      • 355.77 kB
      • 1,200 × 1,600
      • 1
  • Ryno
    70
    • June 11, 2025 at 5:28 AM
    • New
    • #11
    Foto
    Images
      • 381.15 kB
      • 1,200 × 1,600
      • 3
      • 175.78 kB
      • 1,200 × 1,600
      • 2
  • Ryno
    70
    • June 11, 2025 at 5:31 AM
    • New
    • #12
    Foto
    Images
      • 444.74 kB
      • 1,200 × 1,600
      • 6
  • Ryno
    70
    • June 11, 2025 at 5:32 AM
    • New
    • #13
    Foto
    Images
      • 539.66 kB
      • 1,200 × 1,600
      • 4
  • Kuka Found mismatched set of
