Does the KUKA KR210 (V)KRC2ed05 robot have the function of synchronizing with the external E1 rotation axis?
  • HHHYen
  • June 9, 2025 at 5:47 AM
  • HHHYen
    30
    Hello everyone, I am in the process of post-processing on Powermill for CNC Robot KUKA KR210 with 1 external E1 rotating platform, Robot uses controller (V)KRC2ed05. I am setting up "Multi-Axis Coordinate transform" but I don't know if this Robot's Controller has the function to control the E1 rotating axis to move in Synchronization with the Robot or not? Or is it just 6+1 form. And if so, where is this function set up on this Controller? Should this function be turned on or off. "<CoordinateTransform Enabled="True/False" TransformOrder="E1">" Anyone with experience please help me, Thank you very much everyone?
    Fubini
    283
    1,905
    • June 9, 2025 at 6:17 AM
    I can not tell you what to do in Powermill but yes robot controllers of Kuka have the ability to geometrically couple robot with an external axis. That is called base external kinematic since it is done by definition of a $base moving with the external kinematic. So first you need to create this base on your robot controller. It then can be activated by $ base = ek(...). You can find multiple threads about this using the forum search.
    Or are you talking only of velocity profile synchronization? In that case there is nothing to do. Velocity profiles of robot and external axes are always time synchronized even phase synchronized. They start and end at the same time and changing velocity profile parameters like velocity, acceleration, ... does not change the Cartesian path of the robots TCP.
  • HHHYen
    30
    • June 9, 2025 at 6:27 AM
    Quote from Fubini
    I mean does this KUKA Robot with (V)KRC2ed05 (VW) controller support the function of real-time motion synchronization with the Rotating Axis so that the RCPT of the Robot moves in sync with the rotation of the E1 Turntable. and if so, how is the function enabled? I have understood how to enable <CoordinateTransform Enabled="True" if the Robot is not synchronized with the E1 and "False" if the Robot is synchronized.
  • robot-cnc
    432
    • June 9, 2025 at 3:28 PM
    is not that simple, there are alot of settings to do, You need an integrator to help adding krc2 internal driver, cables, settings in machine.dat.
    Is important also to well configure real robot with Rotary table in the Powermill .
  • HHHYen
    30
    • June 9, 2025 at 11:36 PM
    Quote from robot-cnc
    Thanks for your response. can you elaborate on the support integration on the controller and the setup in machine data? as for the robot configuration in Powermill I think I can do it. thank you.
  • panic mode
    1,297
    13,141
    • June 10, 2025 at 5:02 AM
    you need someone to start by collecting data on your own controller. does it have any servo drive for external axis already? with or without SBM? how is it powered? any bottlenecks such as transformer, line fuses, etc?
    then integrate missing hardware and configure it.
    then measure root point to get mathematical coupling.
    btw just recently i did the same on a robot with two external axes and while everything was working fine from the robot side, there were challenges to setup the grasshopper or whatever they use. in the end they found it is easier if the turntable is not coupled, they just let their software calculate turntable positions.
  • HHHYen
    30
    • June 10, 2025 at 9:29 AM
    Quote from panic mode
    I have configured and executed the manual movement commands and programmed each test run, the E1 axis is already working. I have just programmed each step in the Robot running style, then the E1 axis runs.
  • HHHYen
    30
    • June 10, 2025 at 9:31 AM
    I am also having a problem that the E1 Axis brakes when stopping with a jerking sound, not as smooth as the Robot.
    My E1 Axis also has a Harmonic Gearbox and a Servo Motor similar to Axis 4,5,6.
  • HHHYen
    30
    • June 10, 2025 at 9:36 AM
    Here is a picture of my E1 Axis configuration, please help me.
  • HHHYen
    30
    • June 10, 2025 at 9:38 AM
    Below is my E1 axis configuration file, please help me.
    Files
    ExtAxesData1.txt 7.19 kB – 5 Downloads
  • panic mode
    1,297
    13,141
    • June 10, 2025 at 1:46 PM
    • #11
    the reason it is not smooth running is because it is not tuned
  • robot-cnc
    432
    • June 10, 2025 at 2:15 PM
    • #12
    share machine.dat file to take a look
  • HHHYen
    30
    • June 10, 2025 at 4:31 PM
    • #13
    Thanks for your help. This is File Machine, please help me.
    Files
    $machine.txt 52.22 kB – 3 Downloads
    Fubini
    283
    1,905
    • June 10, 2025 at 5:07 PM
    • #14
    For a synchronized move external axis has to be kinematically integrated into machine.dat as a base kinematic. The section starting with $ex_ax_num is not configured in your setup. Get external axis documentation from KUKA or from inside this forum. Also consider
    Post
    RE: moveable Bases with a linear axis.
    Basis auf einer Linearachse - KUKA Roboter - Roboterforum.de - die Industrieroboter und Cobot Community
    Quick Deepl Translation:
    Of course you can do this with the KRC. But admittedly you have to be a bit tricky. If I understand the problem correctly, you want a base that moves with the KL, similar to a base on a rotary tilting table, for example, and then moves on this base. Now you already have a configuration in which the additional axis kinematics is configured as robot kinematics (of type…
    Fubini
    June 20, 2024 at 4:27 PM
    Post
    Re: 2 external axis+ceiling robot
    the transformation chain for any external kinematic is (see R1/$machine.dat)
    $ETn_TA1KR(Ex1) : $ET1_TA2A1(Ex2) : $ETn_TA2A1(Ex3) : ETn_TFLA3, n = 1,..., 6 (n = number of the external kinematic),
    where always the "z-axis" inside these coordinate systems is the axis of revolution/translation according to the axis type (linear/rotational, see $AXIS_TYPE).
    Which axes Ex1, Ex2, Ex3 are used inside which external kinematic is defined by $ETn_AX, n = 1,..., 6 (n = number of the external kinematic).…
    Fubini
    June 18, 2016 at 12:44 PM
  • HHHYen
    30
    • June 10, 2025 at 5:15 PM
    • #15
    Quote from Fubini
    Post
    Fubini
    Post
    Fubini
    Thank you, I will look into this tutorial.
  • robot-cnc
    432
    • June 10, 2025 at 9:27 PM
    • #16
    Quote from HHHYen
    The file machine.dat file you sent shows you did not configured 7-th axis as you indicated in above photos in external kinematic configurator.
    No external axis been added. If it was machine.dat was completed with motor parameters.
