Hi everyone, there are FANUC ARC Mate 100iD welding robots in our welding section. We managed to get the log data (especially errall.ls file that records made works) recorded by these robots via Ethernet and then ftp. While doing this process, we connected an Ethernet directly connected to our system to the empty port of the Ethernet ports on the controller (The controller has 2 ethernet ports, one was empty, other one is used for robot communicating). However, the connection of the robot to the controller is lost after a short while. After this connection is removed and the machine is turned on and off, the error is fixed. Our server is mainly using 0 group of IP address range, robot is using it too, in other CNC machines, I solved the problem via adding 1 group of IP address, I believe that if I can assign a 1 group of IP address which can be 192.168.1.104, we can connect the robot to our server. Thank you in advance for your help.
console image
Edit: In Host Comm page, pressing F3-PORT didn't make any port change, I also tried to assign new port in the SETUP RIPE page, changed the Port #: 1 to 2, but it resets to 1 and the 192.168.1.104 to old value automatically when I tried to press any key or exit the panel. Couldn't find a save option of assignment of 2nd port.
