KRC5
KSS 8.7.6
On one of our welding systems, we have built a fairly robust user stop/start into IR_STOPM, largely to allow for automated recovery from a user initiated E-Stop. This is primarily to allow a user to E-Stop the system at will and to have the system re-establish a weld bead from the point of the stop once the E-Stop has been cleared, all safety requirements are met, and the user initiates recovery. This has been heavily tested and works flawlessly.
However, there are a number of other factors that the welder monitors and reports to the robot controller during the weld that we'd like to have automatically initiate the same process as the user initiated E-Stop, i.e. when the welder reports $IN[2050]==TRUE, run IR_STOPM which stops the weld, locks the welder into a safe mode from which it cannot ignite an arc, stop motion, turn off shielding gas flow, etc. However, as braking only occurs in IR_STOPM when $STOPMESS is true and $STOPMESS is write-protected, I've yet to find a way to call IR_STOPM programmatically and have it perform exactly as a user E-Stop. For example, is there way to use a standard interrupt to call IR_STOPM with full functionality such as:
; ... within weld_program.src
; $IN[2050] input from welder to controller, reports if there is a detected weld error.
; this input is declared within config.dat for global access.
; $IN[2060] input from welder to controller, reports the specific weld error number when 2050 goes TRUE
; not specifically used here, but added for awareness for recovery code
DECL INTERRUPT 5 WHEN $IN[2050]==TRUE DO IR_STOPM()
; ... weld_program.src continues below
To be clear, this is not meant to try and trick or work around safety, as the system is completely locked out any time an E-Stop is called. We're simply trying to use the stop and recovery designed for manual E-stops to help automatically stop the weld if there is an error detected by the welder and reported to the robot controller to prevent the process quality from being diminished by arcs continuing in suboptimal states. Is there a way to do so and call IR_STOPM in such a manner that it will behave exactly as if a user has hit the physical E-Stop, but from an interrupt within a program? If we simply need to write our own ISR and duplicate/move some of the recovery code into this separate ISR that calls BRAKE regardless of the status of $STOPMESS, that's totally fine; we were hoping to avoid code duplication and use the already tested and proven code within IR_STOPM.
